It is currently Fri Jul 18, 2025 10:37 pm
PostPosted: Fri Jul 05, 2013 2:55 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm working through my first ever uke, a tenor of my own design. I have the body made and am ready to layout the neck and fretboard. I want to use the fretboard thickness to help tweak the string height at the bridge but am not 100% clear on what the action height at the 12th fret should be my goal (this is the first time I have done anything with nylon strings). I would also like to know what the typical bridge height and saddle height are for these little buggers. I have a slight angle built into the top like I would for a steel string; I think I'm where I need to be, but if I am going to need to cheat a little now is the time. . .
Bryan Bear PMoMC
PostPosted: Fri Jul 05, 2013 4:09 pm
First name: duh
Last Name: Padma
Yo, Bryan
Cheating not allowed. :!:
The information you are requesting has been deleted from me memory banks gaah and
an, Official Class D, lever 7 clearance is needed to obtain this info on the OLF laughing6-hehe
Go here
http://ukuleleunderground.com/
sign up, do not confess to knowing me, pfft make a donation and ask your question again.
blessings
..... duh
........?adma
PostPosted: Fri Jul 05, 2013 4:38 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm a bad liar, what if they ask if I know you? Change the subject?
Bryan Bear PMoMC
PostPosted: Sat Jul 06, 2013 8:36 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I set my action at 0.09" at the 12th fret. Thats kinda mid-high action for a tenor. It really depends on the player though...some strum hard and want high action, some finger pick and want lower. I try to leave about 3/16" saddle above the bridge so the action can be lowered easily.
PostPosted: Sat Jul 06, 2013 1:10 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks Kevin, just the ku d of numbers I wanted. I start with an I between saddle height. This is getting donated so I don't know what the owner will prefer, better to give them some wiggle room.
Bryan Bear PMoMC
